pioneer vsx-c502
Discussion in 'AV Receivers & Amplifiers' started by av_novice, Jan 2, 2005.
Tags:
  1. av_novice
    av_novice
    Jan 2, 2005
    13
    just starting out on the home cinema diy path, and the vsx-c502 seems very user friendly (scart connections etc), anyone own one, or know of it before I buy ?
  2. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    I don't know much about the new C502, but I know there are quite a few owners of the C301 and based on that, they are very pleased with its abilities and quality, and I would think that C502 would be a really good buy if you need the scart functions.
    And by me adding a comment I'm pushing the thread to the front and perhaps others will start chipping in ;D
    Wasabi
  3. ccparkhill
    ccparkhill
    Oct 18, 2003
    507
    London, SE1
    +14
    The stereo connections for 6 channel inout are via the scart input, so say you wanted to connect the 575 for DVD-A/SCAD the hi-res stereo audio would go through the scart and the rear surrounds, centre and sub would go via 4 RCA interconnects. Never seen it done like that before.
