Pioneer Vsx C402 Optical Links
Discussion in 'AV Receivers & Amplifiers' started by AFCB01, Jul 8, 2005.
Tags:
  1. AFCB01
    AFCB01
    Being quite new to all this I have got the above amp/receiver and am trying to connect 2 optical leads one to sky plus and one to a Panasonic E50
    Much as I try I can not get digital sound from both when they are connected ie one is digital and the other is analogue
    Am I missing something glaringly obvious - perhaps somebody could also confirm the sound settings I should have on sky plus (sure that I have that right) and for the E50 in case that is causing it
    Any help greatfully received
  2. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
    If you've got the Panasonic connected through the DVD input, in the system setup make sure you have "Opti" assigned to the DVD, not "Coax". Press the system setup and scroll right until you find the option. I think it's coax by default, hence you'll only get the audio through scart.
