Pioneer VSX-C300 Tuner problem
Discussion in 'AV Receivers & Amplifiers' started by Dan666, Feb 2, 2003.
Tags:
  1. Dan666
    Dan666
    Jul 4, 2002
    144
    I have a VSX-C300 AV Receiver. The problem is that no matter what input I have selected, every now and then it will switch over to the Tuner input of its own accord. The word "OTHER" also appears in the display.
    I have tried removing the batteries from the remote and other remotes in the room in case they are interfering with the unit, but this does not solve the problem - the unit still switches itself over without warning.
    When it happens in the middle of a DVD its very annoying.
    Any suggestions? I'll post more set-up details if needed.
