pioneer VSX-C300 problem
Discussion in 'AV Receivers & Amplifiers' started by shaunthedude, May 13, 2002.
Tags:
  1. shaunthedude
    shaunthedude
    I have the above amp and the centre speaker is now not working. It is hissing but no sound is coming out of it. I tried another speaker with new wire but that is the same. I checked the settings etc but when i come to centre speaker the dispaly on the amp says "centre- NON" Any ideas as to how to fix this.
    cheers all
    shaun
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,495
    If it wont let you select a centre speaker in the setup menu then it looks like you´ll have to take it to a shop and get it looked at.
    Could be a short somewhere?? or the centre channel amp might have blown??
    Best get it to a service centre.
  3. shaunthedude
    shaunthedude
    cheers matey.Just been doodling on with it and it now works. i have no idea what I did but its ok now.
    cheers anyway
    shaun
