pioneer vsx-c100 set up problem
Discussion in 'AV Receivers & Amplifiers' started by jtfab75, Aug 15, 2004.
Tags:
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    got this today and there's no sound from it (except when i do the 'tone test')
    i'm using red,white and yellow leads from my panny e55 to the pioneer.
    do i need the optical cable only (if so i have get 1 tomorrow)
    when i work the master contro it only goes from/to 0 to -50. shouldn't it go above zero ??
    tryed with a dvd film and radio but still no luck.
    pls help
  2. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    got the radio working,now just the dvd.pretty sure its the cables !
  3. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    all working now.had plugged the audio cables into dvd in the back of the pioneer,then tried dvr/vcr and speakers came into life.phew...i'm worn out.
    ps sounds great !!!
