Pioneer VSX AX5i true 6.1?
Discussion in 'AV Receivers & Amplifiers' started by Murray, Nov 22, 2004.
Tags:
  1. Murray
    Murray
    Nov 12, 2004
    194
    Auckland
    +3
    Will my AX5i play true 6.1 or 7.1?
    If so does it play 6.1 on THX,Pro Logic11?
    The only 6.1 I see is NEO:6 Cinema is that what Im ment to use and is it something that is decoded true?
    I dont think this amp is right for true 7.1 am I correct?
    If you have aset up for 7.1 with 2 rear speakers do they both play in mon :rolleyes: o if its a 6.1 film?
  2. MikeFish
    MikeFish
    If I'm not mistaken it will play true 6.1 and 7.1 in Dobly Digital EX, but this would be dependant on the source being encoded with this (not many discs are I think).
    You can also drive a 6.1 set-up from a stereo source using pro-logic II. The later AX5ai has pro-logic IIx which will drive a 7.1 set-up from a stereo source.
  3. recruit
    recruit
    Murray there is only 6.1 availible ie DD EX or DTS ES the 7.1 is made up by useing 2 speakers but they both produce the same sound "MONO" there is no true 7.1 source out there at present only 5.1 or 6.1!
    John
  4. MikeFish
    MikeFish
    Oh well, it seems I am mistaken! :blush:
