Pioneer VSX-AX5i setup
Discussion in 'AV Receivers & Amplifiers' started by jborer, Jun 10, 2004.
Tags:
  1. jborer
    jborer
    Feb 12, 2004
    53
    I've just got my pioneer amplifier and wondered if I could do these two things.
    I have set the remote control up so that when I press the TV/Sat button after the multi operation button it switches to the correct AV channel on my plasma. I was wondering if I could make it do this without pressing the multi operation button first - make it a bit more family friendly.
    Also, is there any way of adjusting the sound level of ony source. The input from my PC is much quieter than the other sources and I would like to compensate for it.
    Thanks.
