PIONEER VSX-AX5i or DENON AVR 3805 - Which is BEST?
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Sep 29, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    PIONEER VSX-AX5i or DENON AVR 3805 - Which is the BEST?
    I have a PIONEER 868iS DVD Player and a SIM 2 DLP display.
    Can the PIONEER be used as a "processor" using the pre-outs to feed another preamp and poweramps for the manin left and right channels?
    Thanks guys! :thumbsup:
  2. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Does the PIONEER VSX-AX5i have the ability to be used as a "processor" using the pre-outs to my hi-fi system?
    ANYONE?
    Thanks.
  3. NC11
    NC11
    Sep 19, 2004
    465
    London
    +7
    as a companion to the 868 the AX5ai is the best option especially with the iLink audio connection.
    not sure about the processor part though...
  4. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    the pio mos def
  5. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    HI, I have a pio ax5i, a 868 and its excellent. I use the pre-outs of the ax5i to connect to a amp.
  6. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    In this (above) configuration does the AX5i still do auto set-up correctly and give you genuine DTS and DD5.1EX etc etc?
    Thanks,
    :thumbsup:
  7. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Yes, the ax5i is used as processor and the front speakers are then powered by a mf amp, the central and surround are managed by pio.
  8. rcwtom
    rcwtom
    Sep 7, 2004
    40
    Hi Kocl
    I'm looking at possibly doing the same setup as you. Why have you decided to get another amp for your front speakers.. is ax5i not powerful enough..
  9. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    I have front speakers power up by an external amp for one reason (stereo), the ax5i is only average in stereo. Because i have external amp with bypass i could enjoy better sound with the front amplication in home cinema.
  10. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    What has anyone heard about the Pioneer AX5i 's replacement?
  11. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    I read somewhere that's gonna be replaced by a AX5Ai.
