Pioneer VSX-AX5Ai-S OSD
Discussion in 'AV Receivers & Amplifiers' started by stvn, Jan 16, 2005.
Tags:
  1. stvn
    stvn
    Hi.
    Someone can tell me how is the VSX-AX5Ai-S OSD??
    A photo will be great.
    How works the auto setup?, good?, bad?
  2. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +6
    OSD is fine. No bells or whistles - just gets on with the job with a simple balck and white presentation.
    Auto set-up is now very good on 5Ai. The sound levels were perfect against my SPL (well I had to know!) bang on 75db. Distances were spot on, apart from 1 speaker, where it was a mamouth 10 cm out.
    The MCACC (or whatever it is called) impressed me the most. Like most, I anticipated that I would switch it off. Gave it a whirl and was impressed - and all my speakers are 'matched' in tone. The cal system is consistant and even knows when my curtains are open or closed. To achieve a 'mean' result I ended up with one curtain closed, other open. :blush:
    I like it alot.
