Pioneer VSX-932 - Fire tv cube keeps disconnecting
meehog
I just bought a Pioneer VSX-932 receiver 2nd hand, and I'm having an odd problem with my fire TV cube randomly disconnecting, and I can't pin down what's causing it. It seems to be a completely random thing, where it just loses signal for a second, and then reconnects and shows the dolby vision logo on the corner.
Sometimes, it only happens infrequently, but other times, it can be every 30 seconds or so and makes it basically unusable.
I've tried different cables, and plugged into different inputs, updated the firmware on the receiver, checked that the fire cube is up to date, but keep getting the same problem. It was fine when I had it connected to my Onkyo receiver.
I'm hoping somebody might have some advice on what I'm missing, thanks in advance for any help.
