Pioneer VSX-922K iPod connector problems
KimS
WhenI try to connect my iPhone (it should be compatible) to the USB port on the front of the unit, I get an 'over current' message, this even happens with the cable supplied with the unit and I just can't understand why, I get the same with apple kit. Anyone any ideas?
AirPlay also very unstable so investing in new router and static IP but overall not enjoying the experience at the moment!
:lease:
larkone
Sounds like a faulty phone, does it happen when you connect it to a PC?
KimS
Happens when connected to ipad as well, as soon as I plug the connector it says over current, having all sorts of problems, Internet radio options freeze on 'genres' so I can't operate that. I'm having a new router installed by BT next week with a fixed IP so will see if that helps, it's a shame it was bought to listen to music primarily (surround sound for tv works fine) and I can't do that.Thanks for the reply!
larkone
Have you tried a different cable as a faulty cable can also cause this. If it still happens then time to take the amp back.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
