webbrewers
My tv's hdmi arc port is enabled and connected to an hdmi input on the receiver. Hdmi arc is "on" on the receiver. I would expect audio from a dvd player connected via the coax input (no hdmi) would be routed through the receiver to the tv and back out via hdmi arc, so I don't have to change the input on the receiver. I thought that was the point of hdmi arc but maybe I'm wrong.
The manual implies that, but there's a note under the section about connecting a device without hdmi that says you have to select the coax under "signal select". Is that to tell the receiver to route the dvd's audio via hdmi or is that to select the coax input on the receiver?
