Pioneer Vsx 859rds Dts Lfe Prolem!!
Discussion in 'AV Receivers & Amplifiers' started by RUWANDIGITAL, Dec 16, 2001.
Tags:
  1. RUWANDIGITAL
    RUWANDIGITAL
    HELP!!!!
    Hello, I red the review about this one.
    I own him too.
    I notice about the inacurate DTS LFE.
    The Reviewer noticed it to.
    My question is:
    How to deal with it?Can i get it fixed it to go to a pioneer fix center?Will it help?
    Also notice for exaple at T2:UE R2.
    Look at chapter 3.When the metal goes down with the title name of terminnator 2.
    You hear a bass.On DD it is a bit stronger dan the DTS one.
    Now watch out this one, go in setup menu and set your center speaker on OFF.
    The center is divided at the 2 front speakers.
    Now whats the same chapter again.
    The bass in muddy in the DD version compared to the DTS.
    But that is not the solution.
    Can you please tell me how to fix the DTS decoder?
    It a chip right.
    Please.
    Regards Ruwan
  2. RUWANDIGITAL
    RUWANDIGITAL
    Nobody can help me??
  3. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,462
    United Kingdom
    +1,921
    If your not happy with it and theres a fault, take it back to your dealer or contact Pioneer directly.
    I remember a while back that Pioneer replaced a model that had problems but i cant recall the number.
    Try Pioneer and see what they say, maybe it can be firmware updated or something.
    cheers
  4. RUWANDIGITAL
    RUWANDIGITAL
    Ok thanks,
    I will do that.
  5. Fuddle
    Fuddle
    I too have this amp and have no problems. My father has reported that like you the bass is a little lighter on DTS but that was on his Sony STRDB940.
    You can on the Pioneer changes characteristics of all the speakers should you should ot have too much trouble getting this sorted out.
  6. RUWANDIGITAL
    RUWANDIGITAL
    Thanks, but what can i change exactly?
    Regards.Ruwan
