Pioneer VSX-811 & DV656A - SACD config Problem
Discussion in 'AV Receivers & Amplifiers' started by BeadleMachine, Jun 16, 2003.
Tags:
  1. BeadleMachine
    BeadleMachine
    Mar 20, 2003
    47
    Hi there everyone - need some help with setting up my amp for SACD's with Pioneer DV656A and Pioneer VSX811 receiver:
    - Bought some audio cables and connected the 5.1 outputs on the DV656 to the 7.1 channel input sockets on the AMP.
    - ran the setup wizard on DV656 and told it everything was connected etc...
    - played a DVDA disc,
    - switched to DVD 7.1 input mode on the VSX8-11 using the "signal select" button on the remote. Display read "Analog" under input.
    - everything sounded good - channels from all speakers etc...
    Then tried a SACD disc.
    -with the amp on exactly the same setting all I got was 2 speakers with sound Front Left and Front Right ??? :(
    - when I selected "auto signal detect" on the amp it selected "analog" but switched itself to "Dolby PRo-logic" mode and didn't sound like multi channel output to me.
    - Was getting sound out of the fronts and simulated rear sounds because of the pro logic mode.
    really confused by this and need some help from anyway who has similar / same setup. I must have the thing wired up correctly otherwise the DVDA disc would surely display the same problem. :confused:
    any help would be greatly appreciate as I spent most of sunday trying to get this to work :mad:
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Two questions ... have you set your 656sa to play the multi-channel track, and has the SACD you're playing actually got a multi-channel track?
    Vikki
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    P59 of the manual - default for SACD is 2 channel
    P60 Audio Output needs to be set to 5.1 - default is 2 channel
    HTH
  4. BeadleMachine
    BeadleMachine
    Mar 20, 2003
    47
    Hey Vikki,
    thanks for the tips.
    I'm pretty sure I tried the multi-channel setting on the 656a, perhaps it is the disc ? :(
    Its the the TOP GUN soundtrack - will look tonight and try again.
    cheers,
    Beadle Machine
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I think the Top Gun soundtrack is only stereo ... not got it but seam to remember it in the shop being only 2 channel
    Vikki
  6. paiger
    paiger
    I would expect this to be a 2 channel SACD as many are. Get DSOTM for the ultimate SACD experience.
