Pioneer VSX - 2011
Discussion in 'AV Receivers & Amplifiers' started by steve k, Jan 19, 2003.
Tags:
  1. steve k
    steve k
    Apr 15, 2001
    714
    Birmingham
    +53
    Hi pep's
    I'v been looking to get the Pioneer VSX- D2011 amps.
    Can you tell me if unbeatable are proper dealers for Pioneer as these are the cheapest i have found at the moment to buy one of these amps off. The reason for asking is i read on one of these replys that the warranty would be void if the amp was a gray import.
    Also can anyone tell me if the speaker i am looking at to connect i.e. B & W 603 or 604 front. B & W LRC 600 or 60 center.
    The rear surronds I am struggling at the moment to find as these have to be small enough speakers to fit above my living room door as this is the only position i have for the left rear was thinking of the M & k series 4 but they are only rater at 4 ohms so don't think these can be fitted to this amp unless someone can tell me different.
    If anyone can suggest some rear small speakers please let me no.
    Thanks Steve Knight ;)
  2. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
    if you buy within the EU you have a one year warranty.
    Taimur
