dig0
Hi there,
I have the following setup:
Pioneer VSX-1326-K receiver
2 x Klipsch RF-82 Towers Bi-Amped
1 x Klipsch R-10SW
1 x Klipsch R-25C
I have run the Full Auto MCACC, and have the tower and center speakers set to Large. The sub is set to Plus.
I would like to know which audio settings I should be using on the receiver. There are few functions that I don't really know much about, such as:
- Auto Surround/ALC/Stream Direct
- Advanced Surround
- Standard Surround
- Home THX
All of these functions have tons of "presets". When I press them, it cycles through all of the different options, and I'm not sure which one I should select. Any help with this would be greatly appreciated.
It should be noted that some of the settings will cause my center speaker to stop working.
1 x Klipsch R-10SW
1 x Klipsch R-25C
- Advanced Surround
- Standard Surround
- Home THX
