Pioneer VSX-1015-S and SACD
Discussion in 'AV Receivers & Amplifiers' started by peter35, Mar 18, 2006.
Tags:
  1. peter35
    peter35
    Thinking of buying the above system can anyone tell me if it's compatable with SACDs or DVD-Audio disks?
  2. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    Washington,Tyne and Wear
    +75
    Yes,it is compatible with both,but you will need a player,or players,capable of playing such discs.
  3. peter35
    peter35
    Cheers, I was thinking of pairing the VSX-1015-S with Morduant short genie. Is this a good pairing?? Is there any other speakers I should add to the short list?
  4. joffy1780
    joffy1780
    Dec 19, 2004
    1,407
    +75
    To be honest mate I haven't heard the genies,or many other speakers for that matter,bit new to all this.
    If you post a question on the speakers forum stating your budget and preferences,there will be loads of people,more knowledgeable than me,willing to advise.
    Good luck.
  5. rhino2k
    rhino2k
    Oct 20, 2005
    6,075
    +1,282
    if you can, go and demo them in a shop.
    everyone has different ideas about what sounds good :smashin:
