Pioneer Vsx-1015 Question
Trevor spencer
no dought a stupid question , but can you fit the binding posts on the back of this amp with banana clips ? im not sure if the black part in the middle of the binding post is removable
jwramsay
I have the 1014. You can banana the 5.1 channels. The rear surround centre channels (7.1) have a black insert that I couldn't remove, so no banana for those 2 channels.
SPURS1882
How?
Trevor spencer
Timmy!!!
PDP-434HDE said:
No idea why, just know it is the case for me!
It's your lucky day:)
I have a pioneer 1011 and have successfully removed the little plastic bits in the middle of the connectors.
Get a very small screwdriver and put it slightly into the middle of the plastic bung hole things. Then carefully lever the screwdriver down to put pressure on the black plastic bungs and slowly pull outwards maintaining pressure on the bungs.
Once you have pulled one out the rest will be out quickly!
Hope this helped.
Tim
Trevor spencer
Hope this helped.
Tim
Yep done that last night and now im all bananaed up so im happy ,
