Pioneer VSX-1011S on-screen display?
Discussion in 'AV Receivers & Amplifiers' started by guyb, May 31, 2003.
Tags:
  1. guyb
    guyb
    May 20, 2001
    642
    Leamington Spa
    +5
    Hi All
    Does anyone know it the Pioneer VSX-1011S has on-screen display?
    Guy
  2. meep
    meep
    Apr 22, 2002
    587
    Ireland
    +46
    Yes,
    in fact, it's essential for some operations as the front LCD gives very limited information 9auto-setup for example).
    Peter
  3. raZorfish
    raZorfish
    No, the VSX-D1011 does not have OSD. Only the VSX-D2011 has (which is one reason other than the auto MCACC to get a 2011 instead)!!!
    Also, the D1011 doesn't have component video connections!!!
    raZorfish
  4. 337GUS
    337GUS
    Nov 1, 2000
    630
    NE Scotland
    +18
    You can do the 2011 mcacc without a display, not convenient but it is posible. My pj is too noisy for it to work. The mic is very sensitive, I even have to turn off the central heating:)
  5. meep
    meep
    Apr 22, 2002
    587
    Ireland
    +46
    Oops
    The question related to the 1011. Sorry about my misleading info - thought it was a 2011.
    On the componenbt vide connections, note that even the 2011 does not convert video formast so it's not possible to input s-video and output component or vice-versa. Just one gotcha with an otherwise excellent receiver.
    Peter
