Pioneer Vsa E06
Discussion in 'AV Receivers & Amplifiers' started by NGD Boy, Mar 9, 2005.
Tags:
  1. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    I have a chance to buy a pioneer vsa eo6 thx amp for £150.... I have tried search engines/pioneer site and cant find any info.... condition is mint....is it worth the buy?
    Has any one got any info on it please ?
    Carl
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    If this is an older pioneer that is THX certified then i belive the following to be true, if i've got the numbers missed up then i'm sorry not sure about it.
    I was looking into ones of these a while ago. It is ment to be good although it lacks DTS is only 5.1 and does not have multi-channel input so you can't use it as a power amp or with SACD/DVD-A.
    If you can live with these short comings it might be worth buying, althoguh something newer but also second hand will probably serve you better in the long run if your gonna use any of the missing features/codecs, i.e. component switching/up conversion, automatic setup. Ment to have good build and does what it does very well but that was a few years ago so it might not still stand (should think that it does though).
  3. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Thanks for the reply... the amp I have now is a kenwood 5050(dd/dts) and is 100w x 5 ....I know it's only a "budget amp" but I think it sounds good... just wondering if the pioneer would blow it out of the water.. so to speak... I can sell kenwod for £70 to a mate who "just starting" and loves the amp anyway... is the pioneer worth it ?
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    £80 (after you get your £70) for what was near a flagship amp, it should blow it away. If you think it's worth the 'risk', the review i saw said that it made the sound move arround the room as if it was coming from the walls rather than the speakers!
  5. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
  6. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Thanks Gaz.... if I bought a dvd player which was sacd/dvd-a compatable would this not link up with the pioneer ?
  7. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    As (i've read) it does not have multichannel input the best you could do is stereo from the source, if thats good enough then :thumbsup: but if not then you may have to look elsewhere, for the money it's good but if there are feature missing that you want or need then there is no point buying this and then upgrading later. So think about it, remember it is strait old stylee 5.1 DD and probably pro logic 1 so on the codec side it is lacking.
    On the quaility of sound it produces in DD it's ment to be good, so if you would be happy with just that and no upgrade path then its right for you.
  8. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Thanks again Gaz... if there is anyone out there with this amp I'd appreciate some more comments please...thanks for looking
    Carl
  9. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    Used to own one. Very musical amp, great for movies too. Built like a starship. Output stages use ten transistors in differential mode for the five channels. There was a third-party aftermarket add-on for 5.1 input, dunno if it was DIY though. Would prob still cost a silly amount for it too even if still available. LD RF input but you may not care.
    HTH,
    Mike.
  10. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Thanks Mike.... condition is described as mint.... worth it for £150 ??
    Carl
    ps.....will be used mainly as dd amp for movies... and a little music.
  11. goatlips
    goatlips
    Nov 22, 2004
    272
    Croydon
    yeah might be, but does not decode dts! Spend a £150 more and you could get a lot newer pioneer model say 2011? Thats even better!
  12. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    IMO, it's just about it's money for £150 as of early 2005 for the quality amps within and build/finish. What was the original rrp ? £1300 ? I wouldn't care about DTS inclusion personally. It's a class product. See what they've gone for on eBay recently and IIRC on our own classifieds not so long ago.
    Mike.
  13. Family Guy
    Family Guy
    Ditto...I to used to own one...it's a whole lot of amp for £150. The way this decodes DD, you won't miss dts...I never use dts anyway...so the answer your looking for is yes, it's worth the money...
  14. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Thanks guys.... just gotta get it now... will let you know how it goes!
    Carl
  15. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    Guys... help me out again ... what is IIRC ?
    Carl
  16. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    "If I Recall Correctly" :)
  17. Family Guy
    Family Guy
    If I Remember Correctly...(IIRC)...
  18. NGD Boy
    NGD Boy
    Jan 2, 2005
    1,888
    newport south wales
    +61
    :( only just manage to find classifieds!!.... could not find the amp though
