pioneer VSA-AX10i
Discussion in 'AV Receivers & Amplifiers' started by steve k, May 22, 2003.
Tags:
  1. steve k
    steve k
    Apr 15, 2001
    703
    Birmingham
    +53
    :confused: Can anyone tell me where you plug the sub into on the Pioneer VSA-AX10i just been looking at pic of back of amp and can,t work out where to plug the sub thanks
    Steve :clap:
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    There should be a Subwoofer Pre-Out. Plug it in there. ;)
  3. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    There are two actually, single and stereo. Looking at the 'amp from the back, they are slightly to the left and below center.
  4. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    A stereo subwoofer out? Please tell me what that is.
  5. BabylonP
    BabylonP
    Dec 10, 2002
    98
    11
    +5
    Actually this is to run two subs (left & Right) which was part of the original THX recomendations. If you use two matched subs it can produce a very nice smooth soundfield in the LFE.
  6. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    Ok, but surely to call it stereo is missleading? It sounds like it's dual mono.
  7. BabylonP
    BabylonP
    Dec 10, 2002
    98
    11
    +5
    I have been told that they are actualy slightly different and that the lfe can be steered by the system. On my system I do get an impression of panning from one side to another. I can only think that the system adds just enough of a signal above the lfe so that you can get an idea of position, but then again I could be completely wrong.
    You are indeed correct both are connected up as in mono but one to the left and one to the right.
  8. steve k
    steve k
    Apr 15, 2001
    703
    Birmingham
    +53
    Thanks for the info.
    What connector do you need to connect the sub and which one would you recommend. The sub would have to hide behind the sette as this is the only place I have space, the distance from the unit to sub would be aprox 5m.
  9. Fjorko
    Fjorko
    Apr 25, 2003
    511
    Port Elizabeth
    +24
    You can get cable made specifically for subwoofers.
    Some prefer to use Y connectors other's not. If you just use one 5m subwoofer cable you should be sorted . ..
    try www.hificables.co.uk
