pioneer vsa ax10
kumamoto
Really depends what you are looking for. If you want a relaible powerful and very competent receiver and are not bothered by hd sound and hdmi connectivity then AX10 is brilliant.
But if you want the latest receiver with all bells and whistle, then the sony3200/5200,pioneer AX4/AX2 or even yamaha 2700/1700 would do very nicely.
But AX10 is way superior to the newer but lesser amps....
morkus
Hi, thanks for replay. Ive had Marantz sr7500 i was using it with b&w 603 s3, 602.5 s3.I found Marantz had no power to drive it. I swoped to Pioneer vsa ax10 Is it good choise. I use Denon dvd A11 player as cd player, is very good.
