Pioneer TV with media box....cables
Discussion in 'Plasma TVs Forum' started by Paul-r1, Feb 3, 2009.
  1. Paul-r1
    Paul-r1
    May 23, 2003
    102
    Bognor Regis
    I have had a search and can't seem to find the answer, so I thought I would ask here.
    I have a Pioneer Plasma TV with seperate media box and I wish to place the media box much further away than the current cables allow.
    Does anyone know if you can extend these cables?
    Paul
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,294
    2
    137
    Airdrie, Scotland
    +1,079
    Hi there - I know that, when I bought mine, it came with a 3M cable between the TV and Media Box, and that it was possible, at that time anyway, to buy a much longer one - I seem to remember it was a 10M one but couldn't be sure. I do also remember being surprised at the high price Pioneer were asking for it, but can't remember now how much it actually was.
    Don't know if that's any help to you.
    Cheers,
    Martin.
  3. mjcairney
    mjcairney
    Oct 26, 2003
    7,294
    2
    137
    Airdrie, Scotland
    +1,079
    Hi again, I had a quick Google around and came up with this - the only one in stock is the one at the bottom which is 10M long but, as I mentioned in my previous post, they are not cheap. Any use?
    Cheers,
    Martin.
  4. sammiesung
    sammiesung
    Nov 12, 2007
    189
    +23
    Hi Paul,
    It does look pricey but I think this is what you are after. Hope it helps.
    STONEAUDIO UK | hi-fi, home cinema, multi-room, design and installation
  5. Paul-r1
    Paul-r1
    May 23, 2003
    102
    Bognor Regis
    That's fantastic but WOW !! HOW MUCH?!?!?!?!? :eek::eek:
    If thats the only option then that's the only option though....hummm
    Thanks again for your help. Your Googling skills are better than mine :smashin:
  6. SilverJDM
    SilverJDM
    Aug 23, 2004
    366
    Amsterdam, Netherlands
    +80
    Try looking at post #27 in this thread
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    You can get longer cables 10m and 12m not sure about extensions tho the DVi component is OK its the MDR that will be tricky. The cables are the same for Sharp LCD's wioth media box (sharp made the media box for pioneer) sharps cables are alot cheaper
