Pioneer to laptop connection
Discussion in 'Plasma TVs Forum' started by paul147, Aug 15, 2004.
  1. paul147
    paul147
    Can anyone tell me if i can sucessfully connect a laptop,Dell Inspiron 9100(which i am about to purchase)?,which has a dvi monitor connector,to my pioneer vx5 amp by way of an dvi-hdmi connector, and displayed on my pdp434.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,910
    The Borders
    +3,126
    Hello Paul
    Your VSX-AX5i AV Receiver must be one of a kind it if has an HDMI Video connector on it!!!
    The DVI Graphic output on your proposed Laptop can be connected to the HDMI Input on the 04HDE Media Receiver with a DVI to HDMI cable (or a DVI to HDMI adapter) - though only if your Laptop can be set to output 480i, 480P, 576i, 576P, 720P or 1080i; in other words the HDMI Digital Input on the Media Receiver is a Video Input.
    There is an Analogue HD15 (VGA) Input on the Media Receiver too and this would be preferable if your running spreadsheets and the like at [email protected] as converting these signals to 720P at 50 or 60 Hz will look pretty soft.
    If your proposed Laptop is DVI-I (Digital + Analogue Out) you can get a low cost DVI to VGA adapter - see http://www.gefen.com/kvm/cables/dvi2vga.jsp
    Best regards
    Joe
  3. paul147
    paul147
    Thanks joe,my mistake (must have been dreaming !!!)i meant the receiver not amp.
    paul
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,910
    The Borders
    +3,126
    Hello Paul
    Too many Sunday Sherbets :)
    Best regards
    Joe
