Pioneer-TF100GB Freeview problems
Discussion in 'Freeview & YouView' started by Maki, Jul 2, 2004.
  1. Maki
    Maki
    Jan 10, 2004
    379
    Overton Morecambe
    +16
    Up until Wednesday night this box has performed without fault. However, it seems there may be a small issue. I struggle to get ITV2, the banner comes up and then the screen goes blank, the station may then appear after a short period, or not at all. The no signal message does not appear and signal strength is up at 95%.
    The same thing is now happening to BBC1, identical in fact. Is this a box problem or is it a Freeview glitch, ie, weather, intermittant weak signal. When BBC1 eventually does appear it is Okay moving up the channels and back again. However, if I move back to a blank channel and then back to BBC1 I have lost it again. I then can retrieve BBC1 by moving up to BBC2 and back again repeatedly until it appears.
    Has anyone any thoughts. My gut feels it is a freeview problem as the rest of the channels are fine and consistant. But could it just be the box!
  2. pob
    pob
    Mar 28, 2002
    1,634
    Sheffield, UK
    +158
    MY dad's Pioneer box is doing exactly the same and has been for a few weeks. ITV2 is getting really hard to pick up.
  3. Barzo
    Barzo
    May 10, 2004
    1,700
    Liverpool
    +473
    I've noticed the same problem over the last two weeks. I wonder if it is a bad software update? I've had the box for months, and it has been working fine up until now.
  4. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    see my other post-Pioneer are aware of the problem and are working on it.Mine was working fine since chrsitmas until this week.........
  5. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Everything was fine until this week. I turn on BBC1, I get a blank picture, it knows its BBC but nothing. All other channels are fine for...if I switch to something else and flick back sometimes BBC1 works. I was wondering if they are doing transmitter work at the moment as its been a fantastic box since I got it last November.
  6. DrPepper
    DrPepper
    Oct 2, 2001
    3,348
    Barking Essex
    +267
    I'm having the same problem:-(
  7. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
  8. pob
    pob
    Mar 28, 2002
    1,634
    Sheffield, UK
    +158
    It says that Mendip is only on reduced power for DAB Radio and Radio Bristol.
  9. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    as i said before-Pioneer are working on it,it's not a transmitter power problem.......
