Pioneer System Cable
Discussion in 'Plasma TVs Forum' started by Michael001, Jul 22, 2005.
  1. Michael001
    Michael001
    Hi all,
    I have ordered a Pioneer PDP505XDE any whilst waiting for it to arrive I need to put the cables in place in the wall on which it will be mounted. Can't seem to get a straight answer about what type of cable(s) link the display with the tuner box. so I can buy them locally Anybody got any ideas? :clap:
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    How long do you need? The std is 3m, but 7, 10 and 30 m is possible. and where is 'local' to you?
  3. Michael001
    Michael001
    Maw,
    5M would be ideal but if 7 is readily available then that would be good. As for local Bunham on Sea, Somerset. Is mail order an option.
    Thanks,
    Michael
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No 5m option, it shares the cable with Sharp LCD monitors. Like to help, but I'm off on my hols tomorrow... I'd guess armed with that info a net search will get you sorted.
  5. SPURS1882
    SPURS1882
    Sep 16, 2004
    395
    Gants Hill
    +16
    Do what i did an order the original pioneer 10 metre system cable from www.superfi.co.uk. It's the same cable as you would get in the plasma box
    The modle no. is PDA-H03 - £200
    Hope this helps
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    But if you can get hold of the sharp 7m cable it's £120
  7. neilball
    neilball
    Jan 7, 2005
    2,748
    Scottish Borders
    +574
    Sharp 7m cable is the AN07SC2 & costs around £100.
    Has anyone tried the DFP-DVI cable adaptors with a standard DVI cable to replace the MDR cable ie. used 2 DVI cables plus adaptors?
  8. Anderzander
    Anderzander
  9. Anderzander
    Anderzander
