PIoneer(?) Speakers
Discussion in 'Home Cinema Speakers' started by trbradley, Jul 16, 2002.
  1. trbradley
    trbradley
    Does anyone have, or know where I could get, the specs for a set of Pioneer (I think) speakers, model no. CS-83W? They're pretty old -scored them off my cousin.
    Also, can anyone recommend a reasonable, inexpensive set of speakers appropriate for the rear centre in a 6.1 channel system? Preferably wall mountable, and about 80W and at least 6 Ohm
    Thanks!
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Sorry Mate, don't know about Pioneer specs for those speakers, so can't comment. However with regard to extra rears, what speakers are you currently using as rears? Is it the Pioneers? Most people recommend using matching speakers for your surround sound, so if you have Missions (for example) at the rear already, then get another Mission so you have a uniform soundstage with matching tweeters. There are plenty of good rears out there in standard, bipole/dipole, etc form, but getting a full matching set is important/preferable.
