Pioneer service menu
Discussion in 'Plasma TVs Forum' started by jaguar, Dec 17, 2004.
  1. jaguar
    jaguar
    Nov 17, 2004
    186
    Does anybody know what the temperature values Temp1 en Temp2 stand for?
    Is it in Fahrenheit?
    And what's the difference between 'Hour meter' and 'MR hour meter'
    :lesson:
    To avoid the 'How do you activate the service menu discussion'
    Switch it off (in stand-by).
    Press the button below the 9 and wait for 3 second (do not hold down the button, just press it).
    Then press left, up, left and right.
    Swith the screen on.
    :lesson:
  2. Ross_R
    Ross_R
    ..my first post on this forum... I've been on North American forums for a while, but just found this place!
    I suspect the TEMP1 and TEMP2 are in degrees F, and I suspect one is for the panel and one is for the media receiver.
    The hour meter is for the panel itself; the MR hour meter is for the media receiver. They're different by a tiny amount -- e.g., on my Pio the panel is at about 600 hours, and the media receiver is an hour or two behind...
    Ross
