Pioneer screen formats
Discussion in 'Plasma TVs Forum' started by jayzeer, Aug 23, 2004.
  1. jayzeer
    jayzeer
    Jul 14, 2004
    27
    Hi, silly question - I am new to the Pio 434 & my Sky+ menu is cropped at the bottom - whichever setting (zoom, wide,cinema etc) I set it to I am losing the bottom of the Sky+ menu & on-screen display. This should be standard stuff shouldnt it? could it be a problem with Sky+?
  2. Quinny
    Quinny
    Apr 19, 2004
    91
    Cambridge
    Is the Sky+ set to 16:9 mode or 4:3 mode? I have Sky+ connected to my Pio 434 and it works well. I think mine is set to Full mode on the Pio. I'm at work so i can't confirm yet. I will post late today or tomorrow if you can wait that long.
  3. jayzeer
    jayzeer
    Jul 14, 2004
    27
    Ive tried it with both settings on Sky+ without joy...dont know where you mean 'full' mode on pioneer?
  4. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    On the plasma handset, press the key which is just below the key with the i+ on it (this is itself below the 9).
    It's just above the volume key, on the right hand side of the row of 4 keys which starts with the PC key.
    This key is the 'mode' key and each press will cycle through Full, Wide, Zoom, etc.
    You need to have it set to 'Full' to display the Sky feed correctly.
  5. jayzeer
    jayzeer
    Jul 14, 2004
    27
    I've tried the mode key - all it does it slightly adjust the picture...what I need to know is what are the Sky+ picture settings & those of the Pioneer...could anyone check & let me know?
  6. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    There are no 'settings' to speak of.
    The Sky+ output should be set at 16:9 and the plasma should be set to Full.
    That's it.
  7. mstodge
    mstodge
    May 6, 2004
    264
    Birmingham
    +5
    you could try the options on the pio, then picture adjust and move it up a touch.
  8. Andy C
    Andy C
    Jul 14, 2004
    119
    16
    Sounds like the overscan is a little too much. If the Pioneer has any options to alter the vertical size of the screen you can correct it.
  9. CJVeggie
    CJVeggie
    Sep 2, 2004
    9
    4
    I am having the same problem on my new 434 - the bottom of the sky+ is being cut off. The only solution I have is to press the teletext button, as this comes through normally, and scroll back to the screen - hey presto, sky+ is normal. Does anyone have apermanent fix for this?
  10. thebigkung
    thebigkung
    How are you guys connecting the Sky+ system?
    I've notice your problem when playing through my old S-VHS (16:9 'ready') Video onto a numbered channel. Will have to investigate further as to what precise situations causes the problem.
    When using Scart RGB or Scart to 'S' onto Input 1 of the media box all is fine.
  11. CJVeggie
    CJVeggie
    Sep 2, 2004
    9
    4
    I have the scart into position 2. I will try position 1 tonight, and let you know. Thanks for your help.
  12. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    The 504 manual states that Input 1 must be used for a decoder.
    Input 2 or 3 for a VCR and Input 3 for a DVD player.
    Input 1 is RGB, Input 2 is S-Video, Input 3 is RGB and S-Video.
  13. CJVeggie
    CJVeggie
    Sep 2, 2004
    9
    4
    Tried input 1 last night, with some success. The picture came on hiding the bottom 2 inches, then flicked into normal view after 1 second. To my frustration, I woke this morning, stuck on GMTV, and the problem was back. I'm starting to get some nagging from the missus over the "amount of money you spent on that set". Should I get an engineer out or something?
    I may be going away from the point, but has anyone had any problem losing lip sync from sky+? Especially noticable on ITV. Would a better quality scart give me a better pic from sky?
  14. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Lip sync is a thorny old problem. Pioneers seem especially prone, I'm off to Wantage today, 75 miles to sort out just this issue. (that's why I try and sell locally) CJ, you do have sky set up right on the STB don't you? RGB and 16:9? A better scart might well help with general picture quality, it depends what you are using now. If it's not fully wired, or is the black nasty sky give you, then any 1/2 decent cable will help hugely.
  15. CJVeggie
    CJVeggie
    Sep 2, 2004
    9
    4
    Thanks MAW, I'll look at the settings when I get home. Sorry to be a acronym ignorant, but what does STB stand for? I'm sure the scart setting is set to the video setting, so I'll change to RBG and see what happens.
  16. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That might well cure your problem then. RGB should be way clearer, better colours, etc. Not necessarily brighter colours, composite video (video or PAL) tends to make them garish. STB=Set top box. Ignorance is curable, not a crime!
