Pioneer SCR39 speakers - OK?
Discussion in 'Home Cinema Speakers' started by meoq, Nov 4, 2004.
  1. meoq
    meoq
    Hey everyone,
    Richersounds.ie have a 3 speaker Pioneer SCR39 package for just €30 (usual price €80). I tried to find information on these, but have had little luck. I'm assuming they can't be too bad if they're pioneer, and they are exceptionally cheap. You can read all about them here:
    http://www.richersounds.ie/asp/ViewProducts.asp?CatID=41&ProductID=3929
    Is there anything I should be wary of with these speakers? Does anyone have any opinion on them based on first hand experience? I'm planning on buying two packs and a sub for 6.1 surround. Thanks :thumbsup:
