Blu-rayx
I have one on order due for delivery next week
Anyone thinking of getting one?
›› Channels: 9
›› Amplification Type:NEW Class D3 (Direct Energy HD)
›› 720 W Multi ch Simultaneous Drive (1 kHz, THD 1 % @ 8 ohms)
›› 210 W/ch (1 kHz, THD 1 % @ 4 ohms)
›› 170 W/ch (1 kHz, THD 1 % @ 6 ohms)
›› 130 W/ch (1 kHz, THD 0.08 % @ 8 ohms)
CONSTRUCTION DESIGN
›› Advanced Direct Construction
›› Rigid Trans-Stabilizer
›› Insulated Dual Chassis
AUDIO FEATURES
›› THX® Select2 Plus Certified
›› Dolby® TrueHD/Dolby Pro Logic IIz/Dolby Digital Plus
›› DTS-HD® Master Audio/DTS-ES/DTS Neo:X
›› Digital Core Engine with Texas Instruments Aureus™ DSP
›› Hi-bit32 Audio Signal Processing/192 kHz/32-bit DAC
›› HDMI® Audio Return Channel
›› Pioneer Advanced MCACC Room Calibration
• 3D Time Axis Measurement
• Polarity Check
• Automatic Crossover Setting
• Reverb Before and After Calibration Results (OSD or AVNavigator)
• Standing Wave Control
›› Pioneer Sound Enhancements
• Full Band Phase Control/Auto Phase Control Plus
• PQLS Bit-stream/Multi-Surround/2 ch Audio
• Jitter Reduction
• Auto Sound Retriever/Auto Sound Retriever for ARC
• Sound Retriever AIR
• Sound Retriever Link
• Auto Level Control (Multi-Channel)
• Advanced Surround (15+1 Modes)
• Optimum Surround (Auto Bass, Dialog, and Surround Balancing)
• Virtual Speakers (Wide/Height/Surround Back)
• Virtual Depth
VIDEO FEATURES
›› 4K Pass Through
›› 3D Ready (Blu-ray Disc®, Broadcast and Games)
›› Deep Colour (36-bit) and x.v.Colour
›› 1080p/24fps Scaler with Qdeo™
›› Triple HD Noise Reduction
›› Advanced Video Adjustment
›› Stream Smoother/Stream Smoother Link
›› Frame Rate Conversion (60i/p 24p)
HOME NETWORK FEATURES
›› AirPlay Wireless Audio
›› DLNA Certified® (1.5)
›› Compatible with Windows 7
›› Music File Playback via LAN/USB (WAV, MP3, WMA, AAC, FLAC)
• 192 kHz/24-bit Music File Playback (FLAC/WAV)
›› Internet Radio with vTuner
CONVENIENCE FEATURES
›› Digital Audio from iPod®/iPhone®/iPad® via USB
›› Android Audio & Video Playback (MHL) Compatible
›› iControlAV2012 Remote Control App Ready (iOS/Android)
• AV Receiver and Blu-ray Disc Player Control from Smartphone
• Sound Explorer
›› Air Jam App Ready (iOS/Android) (Optional AS-BT200 adapter required)
• Share Music and Create Playlists via Bluetooth® Connection
›› Wireless LAN Converter (AS-WL300) included
›› Firmware Upgrade via Internet or USB
›› AVNavigator for Easy Wiring and Setup with PC or iPad
›› Graphic User Interface (GUI) with Album Artwork (HDMI only)
›› Auto Power Down
›› Power Save for HDMI Standby Through
›› AM/FM Tuner 63 Presets
›› Sleep Timer
›› Learning Remote Control (Illumination)
›› RF Remote Control (CU-RF100-U) Ready
FRONT TERMINALS
›› HDMI 1 In (assignable/MHL)
›› USB/iPod Video In
›› MCACC Setup Mic In
›› Phones 1 Out
REAR TERMINALS
›› HDMI 7 In (6 assignable)/2 Out
›› Ethernet 1 In
›› AV (Composite) 4 In/1 Out
›› Audio 1 In (assignable)
›› Digital Coaxial 2 In (assignable)
›› Digital Optical 2 In (assignable)/1 Out
›› Component Video 2 In (assignable)
›› Monitor Component 1 Out/Monitor Composite 1 Out
›› Preout 9.1 ch (11.2 ch terminals)
›› Speaker 11 ch Out (SB/FH/FW/B, FH or FW/B assignable)
›› Bluetooth Adapter Port for AS-BT200
›› USB Charge Port for AS-WL300 Wireless Converter
›› IR 2 In/1 Out
›› 12 V Trigger x 2/RS-232C
ZONE FEATURES
›› ZONE 3 Audio, Volume and Balance
›› ZONE 2 AV (Composite), Subwoofer, Volume, Balance and Tone
SPECFICATIONS
›› Power Requirements: AC 220-230 V, 50/60 Hz
›› Power Consumption: 330 W/0.1 W (Standby)
›› Dimensions (W x H x D): 435 x 185 x 441 mm
›› Weight: 15.3 kg
›› Channels: 9
CONSTRUCTION DESIGN
AUDIO FEATURES
• Polarity Check
• Jitter Reduction
• Virtual Depth
VIDEO FEATURES
›› 4K Pass Through
• Sound Explorer
›› Auto Power Down
›› Sleep Timer
FRONT TERMINALS
›› Phones 1 Out
REAR TERMINALS
›› Ethernet 1 In
›› IR 2 In/1 Out
ZONE FEATURES
SPECFICATIONS
›› Weight: 15.3 kg
