mick24402400
Established Member
Roll On Saturday. Should Receive my new
amp.
Pioneer SC-LX901 AV Receiver
amp.
i had a lx79 you can tell the diffrence music sounds so much alive now and films are superbThats great news mine is not set up yet still in the box.
What did you upgrade from is it a big improvement
I have found this applies to every receiver I have tried.dont use the mike your best off setting it yourself
Hope your LX801 has arrived okay.Let us know what you think of it. I'm getting the pioneer sc-lx801 next Wednesday I hope it's a good upgrade from my denon 3312
As I said, I've checked all those settings. Tried all the settings in various combinations too. I think it's actually the channel's programming issue.On your remote click AV ADJUST, then scroll down to OTHER, the scroll to CENTRE SPREAD and that should be to OFF, also DIALOG ENHANCEMENT should be off,
Glad it's not the amp then, funny you should mention the centre channel, I'm having trouble adjusting that,I have the 701, and my centre channel sound a bit muddy, not very clear, but it doesn't happen with all the channel, Amazon and Netflix are fine, but BBC doesn't seem to like it, I've changed the setting to flat, just on the centre, that seems to help a bit, I've always thought was the ampJust re-plugged in my 2021 and it's the channels on sky not the receiver. Happens on the HD channels apart from he sky ones that actually do output 5.1 (movies, Living HD (CSI) ) Very odd. Also, the Center spread option makes no difference, whereas with the movie channels the Center spread ON makes it sound just like the other channels. Perhaps there's a Dolby Digital tag on those channels that is forcing the Center spread to be switched on without the ability to turn it off?
