Pioneer SC LX87 Remote
Discussion in 'Home Cinema Control & Remote Controls' started by DEYRES, Jul 13, 2015.
  1. DEYRES
    DEYRES
    Dec 23, 2014
    12
    Essex
    Hi All
    Looking for some Pioneer SCLX owners to confirm how the remote should work. I purchased an open box Pioneer SC LX87 from Richer Sounds which was missing the remote. I managed to get a replacement from another company, however it appears that many of the keys dont work. For example the cursor navigation or pretty much all of the keys on the lower portion of the remote. Changing volume or input works fine, but its not much use as it is and I have a pronto that will do that. Id rather have the original remote so i can program the pronto and if i ever re-sell it.
    Can someone with a LX87 please confirm that the remote's cursor navigation keys should work (ie in on screen menus, navigating media files etc)
    What the model number of the remote should be (its on the front of the remote)
    It could be that this is how it works or it could be a cheap (although it cost be a fair bit) Chinese knock off that dosnt work or its broken. So if someone can confirm how theirs works that would be great.
    Thanks in advance.
    Dave
  2. DEYRES
    DEYRES
    Dec 23, 2014
    12
    Essex
    Anyone?
  3. Bobby2012
    Bobby2012
    Jan 4, 2013
    213
    Welling, Kent
    +42
    Hi Dave
    Sorry it's late reply, I've just noticed your question.
    I have an LX86 and can confirm the keys do function as per your query.
    The remote model number is AXD7668.
    I hope this helps.
  4. Madian
    Madian
    Apr 1, 2005
    57
    11
    Crawley, West Sussex
    +4
    I have an lx 87, my pioneer remote is the AXD 7698, hope that helps you out.
