Pioneer S-V710-III or Panasonic SBTP70 ???
Discussion in 'Home Cinema Speakers' started by kch1888, Sep 11, 2004.
  1. kch1888
    kch1888
    I was wondering if anyone could advise me as to which of these speaker systems is the best. Either will be connected to a pioneer vsxd814 a/v receiver. Ive been led to believe that the panasonic set has the edge because its frequency response is identical for its front and rear speakers which is important for dvd-audio?!?
    Can anyone point me in the right direction or advise on alternatives to these speakers, both retail for around £500 to £600.
    Thanks.
  2. Worm
    Worm
    Mar 4, 2003
    246
    +8
    I was just looking at these today and was going to ask the same question.. so anybody?
  3. kch1888
    kch1888
    Hi Worm,
    when I asked that question I was putting together my first 'real' home cinema system. I was advised by a number of specialist audio centres that I should infact ignore both options and go for tried and tested speakers from a specialist manufacturer. I ended up with the Acoustic Energy Evo 3B home cinema set, which I must say are terrific, even if slightly more expensive at around 750-850 online (approx 900 in shops)!
    Hope that helps, or at least gives you something to think about!!
    Cheers.
  4. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Thanks for the reply.. Have heard the Panasonic ones and they sounded superb and I reckon with my Yamaha 757 receiver should be even better.
    Seen prices from 460-735 but yesterday ordered them from Peter Tyson for £260 incl delivery.. Well good bargain!!
  5. kch1888
    kch1888
    Well listening is always the best way! Looks like you got a good deal as well :thumbsup:
