Pioneer remote control
Discussion in 'Home Cinema Control & Remote Controls' started by bailda, Sep 13, 2007.
  1. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Does anyone know if you can use remote controls from other Pioneer plasma's.
    I have a PDP-433HDE and my remote is a bit knackered and have seen lots of Pioneer remotes on Ebay and the like but not the specific one for my Pio.
  2. ashv12
    ashv12
    Mar 17, 2006
    573
    Huddersfield
    +47
    hi mate
    not sure if this is any help to you but my av receiver remote works my tv and cd player i have 3 pio remotes but i only ever use one i would think you will be ok pioneer remotes do tend to be very universal hope this helps:thumbsup::thumbsup:
  3. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Thanks for the reply. Thats good to know but the only worry I think I'll have is the specific buttons on there e.g. screen res, menu etc.
    Might be safer to bite the bullet and pay out for a proper replacement.
