Pioneer receivers (ax3, ax5) remote & Sky+
Discussion in 'AV Receivers & Amplifiers' started by darrens, Dec 15, 2003.
Tags:
  1. darrens
    darrens
    Nov 2, 2003
    97
    Hi there, I'm just about to buy a Pioneer receiver (still deciding between ax3 and ax5) but was just wondering if you could use the remotes for either of these amps with sky+.
    I haven't got a universal remote and it would be nice not to have to buy one if I could the remotes from one of these amps.
  2. Brogan
    Brogan
    Oct 9, 2003
    7,476
    Cary, North Carolina
    +481
    You can program the AX5 remote to operate Sky+ which is better than operating your amp volume with the Sky remote.
    You can also rename the keys so when you press them it displays Backup, Pause, Play, etc.
