Pioneer recall
Discussion in 'AV Receivers & Amplifiers' started by graham_ew, Jan 31, 2001.
Tags:
  1. graham_ew
    graham_ew
    I dont know if this has posted anywhere else but ill do it anyway:-
    My friend called today saying in the Daily mail pg30 there is a PRODUCT RECALL for:-
    PIONEER VSX 839 RDS
    VSX 859 RDS
    call Pioneer AV HELPLINE on 0800 085 0202
    hope this is of any help to anyone
    Graham
  2. RUWANDIGITAL
    RUWANDIGITAL
    What do you exactly mean with recall???
    Have this product some problems with it's electronics inside this wonderfull machine?
    Yes I am a verry pride owner of this amplifer but if this product not in a good condition ......
    Gr.Ruwan
  3. graham_ew
    graham_ew
    I think the problem is to do with the units shutting down and even smoking (but apparently no chance of fire) dont know if its just UK models but the ad said recievers sold from NOV 2000 onward (I see from your profile you are in the Netherlands so you could be ok ,,, unless you have a UK unit)
    Graham
  4. graham_ew
    graham_ew
    Recall means they need to go back to the manufacturer or service agent for modifications
  5. Dave
    Dave
    Yep its true if you own one of these above machines, purchased from last November your gonna have to say bye bye to it, but its not all bad my friend purchased the 859 just over 2 weeks ago. After a couple of calls to Pioneer they sorted out to pick up his 859 and replace it with the 909, not bad huh, of course he's over the moon, they swapped them over today, I'm sure you'll see a gagging review of it on this very thread soon [​IMG]
  6. RUWANDIGITAL
    RUWANDIGITAL
    I have it purchashed on 12-10-2000 in holland.
    It doesn't hurt to call I guess.
    He Dave.
    Have you als owned the 859 and get you the 909 back instead???
    How do you do that.
    So i call up tomorow and say that I would chech this thing and I get the 909???
    Imposiblle but when you get you get it.
    Tell me some more please.
    Gr.Ruwan
  7. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,772
    7
    2
    167
    Birmingham, UK
    +10,683
    Blimey, how many times do I have to point out that there IS a news section to this site ?!
  8. Stick
    Stick
    So can you have smoke without fire then? Pioneer seem to think so!!. They did have an Advert in the Mail yesterday, and they were keen to down play the potential seriousness of the problem.
    If you have one of the affected units, then DEMAND an upgrade. After all it will be YOU who has to spend time disconnecting it from your system and then getting it back to a dealer not Pioneer. This all takes time, effort and petrol!. You have all invested your money & time in Pioneer, and for them to release a product with a fault such as this is unproffessional in this day and age. So get on the phone to either the dealers or Pioneer HQ, and complain, make fuss, be awkward. You will get an upgade if you are prepared to be a pain in someones neck.
    Oh my god!, I think i'm turning into Ann Robinson!!!!....I am the weakest link-goodbye!!
  9. nickeng
    nickeng
    Call Pioneer, and they said they would swap it for a 909, I recieved the 909 the next day, hand delivered by the same person i spoke to in Pioneer
    A must better amp, full THX Ultra spec, better build quality, more sockets...
    Thanks Pioneer you have made my year and its only February!!
  10. RUWANDIGITAL
    RUWANDIGITAL
    Ah,well I live in the netherlands so can I also call to the headquarters en complain to??
  11. nickeng
    nickeng
    I though it was a European recall, but i may be wrong..
    There would be nothing wrong in calling your home country Pioneer office and asking 'nicely' if this is true..
  12. Colonial Marine
    Colonial Marine
    Dec 8, 2000
    37
    London, Uk
    Hey Ruwan, I read the recall info in a local paper & it said that MOST of the units were sold in europe, so check it out!
    I say we take off and nuke the entire site from orbit.....it's the only way to be sure.
  13. RUWANDIGITAL
    RUWANDIGITAL
    Thanks Colonial Marine,
    I'll check it out on a Monday.
    I'm worry about It.
    Mybe i can also ask for a 909.
    "No", you have..."Yes" ,you can get.
    Greets Ruwan
