  • Black Friday Deals
    Visit our Black Friday page for our frequently updated, hand picked deals on TVs and other tech.
Pioneer plasma help needed with 360 pls help.
OfficialSono
Good Evening folks
Right i have a small problem
i have my pioneer hdtv here and i have the pioneer HDMI unit also.
can someone please help
i have a xbox 360 plugged in via the hdmi unit using the 360 Hd cables that came with the console.
yet i cannot get 720p or 1080p at all, it just shows a black screen.
i am obviosly doing something wrong can someone please help.
Thanks in advance for any help
Sono
chaparral
i have my pioneer hdtv here and i have the pioneer HDMI unit also..
What do you mean by you have the pioneer HDMI unit also ???
Am i right in thinking you mean the pioneer plasma ext media tuner box which came with your pioneer plasma..
Which model pioneer plasma do you have ???????
You have made a mistake with the name of the cable your using for your xbox360..As it is not possible to get a HDMI cable for the xbox360..
The xbox360 has no HDMI output..
The following cables are avilable for the xbox360
(1) Component HD AV Cable
(2) Advanced SCART AV Cable
(3) VGA HD AV Cable
(4) And i think there a S.Video one out as well..
http://www.xbox.com/en-GB/hardware/
frank-e-boy
Have you adjusted the settings i your xbox? I had this problem, you cant just switch the swtich on the cable the HD and get it to work. Cant remember what I did now but search google for an XBOX faq and it will tell you how to sort it. Good luck
scottymc
Hi mate
I have an 436xde my xbox came with component leads which you just plug into the input2 (component connection) you use the the scart for your sound
also have you swiched the xbox lead to hd?
