Pioneer plasma fault
Discussion in 'Plasma TVs Forum' started by coopster1974, Aug 4, 2005.
  1. coopster1974
    coopster1974
    New to the forum so go easy on me! :hiya:
    Anyway, I've just inherited my brothers broken Pioneer plasma.
    Model number is PDP433HDE.
    Anyway the problem is that when its powered on the pixels "light up" ie there is a faint flicker of the pixels but that is all. My brother thinks it might be a power issue whereby the internal fuses of the screen are shutting down in order to stop a surge? Personally I think its a media controller issue.
    Anyone experienced anything like this or can recommend a good Pioneer repairer in the Sheffield area?
    cheers
    Chris
