Pioneer plasma 436XDE question...
Discussion in 'Plasma TVs' started by mr_b_at_home, Aug 26, 2005.
  1. mr_b_at_home
    mr_b_at_home
    Jan 23, 2005
    130
    Inverness
    +5
    Hi Folks
    I am considering buying the new 436 screen but need to get my cables laid in the next couple of weeks (no guarantee of the screen arriving in time). My question - is the 10M extension cable (PDA H03) compatible with the new screen and media box. If it is I can order it and get it put in and wait for the screen to arrive.
    Anybody know for definite :confused:
  2. ikon66
    ikon66
    Mar 22, 2005
    397
    Tyne & Wear
    +7
    Pioneer CS are very good I've used them a couple of times and responses were very quick and accurate.
    You could download the manual which is available on-line now I think, that might help
  3. mr_b_at_home
    mr_b_at_home
    Jan 23, 2005
    130
    Inverness
    +5
    Thanks for the advice. I phoned Pioneer UK and (after eventually getting through) they advised that the cable was compatible. Ordered one today for £194 delivered (cheapest I could find) and have a screen on pre-order :smashin:
