Pioneer PDPLX508D arrived... is it a dud??
Discussion in 'Plasma TVs Forum' started by markygfaebburn, Jan 18, 2008.
  1. markygfaebburn
    markygfaebburn
    Jan 13, 2008
    Blackburn
    Got my tv this morning, plugged all my inputs in, plugged in the power... nothing happened!
    press power on side of set, press it on remote, tv doesn't come on! not lights or anything. :(
    My sky, wii etc have all powered up & my cable is in correctly
    anyone able to help at all? :lease:
    thanks
  2. markygfaebburn
    markygfaebburn
    Jan 13, 2008
    Blackburn
    whoops, wrong forum
  3. BasicAudio
    BasicAudio
    Jan 4, 2008
    15
    3
    Make sure everything is plugged in tightly swithched on and make sure there are no 'hard off' buttons or swithches on the back.
    If you can try the lead in something else (if it is detachable) like a PC or try a cable from something else.
    Also try another socket incase there is a problem with it.
  4. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Moved from LCD to Plasma forums.
    Curly
  5. garciag5
    garciag5
    Jun 16, 2005
    Ireland, West Coast
    +5
    There should be a hard-power button on the bottom of the screen in the bottom-left corner. Maybe that's it.
  6. kjt2004
    kjt2004
    Dec 16, 2005
    1,762
    Surrey
    +165
    Isnt there a seperate power switch underneath the plasma or at the back if i remember
    regards
