Pioneer PDP507XD - simple question about football picture
Discussion in 'Plasma TVs Forum' started by amrad, Apr 25, 2007.
  1. amrad
    amrad
    This is probably a really stupid question - on our 507xd when we watch football we can either watch it letterbox format with vertical bars on the left and right of the screen or some sort of zoomed format where the sky information bar at the bottom of the screen is lost and some of the logos etc.
    Can anything be done about this?
  2. gkaram
    gkaram
    If you want to view the broadcast across the screen you should use Wide option and loose some but not all otherwise watch it in letterbox format
  3. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Assuming this is a dodgy non-widescreen broadcast on ITV? Not much you can do apart from the viewing modes already mentioned. This isn't specific to the Pioneer.
    You do have your Sky box set to 16:9 in the picture settings, presumably?
  4. amrad
    amrad
    I'm talking about sky broadcasts as well.
    Setting the picture to 16:9 on the sky menu gives the 'zoomed' version which moves the score and sky logo at the top in from the side and when bars come up on the bottom of the screen with scores, stats etc they can't be seen.
  5. AndrewTheMuppet
    AndrewTheMuppet
    Dec 3, 2004
    195
    +3
    Don't watch ITV !
    They can't be bothered to film in Widescreen, I can't be bothered to watch.
    Have ITV mentioned HD anywhere... no.
    While the BBC and Sky are at least trying to show us what they can do, ITV are still producing in 4:3... great! losers.
  6. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    Sky Sports?
    Something is wrong here - SS1 and 2 are always 16:9 broadcasts so having the box set to that & the TV set to it should give a fullscreen picture
  7. Bumtious
    Bumtious
    Oct 26, 2005
    8,126
    Prestwich Manchester
    +7,650
    There is something very wrong here.
    The Sky box should be set to 16:9 and the set should automatically switch how have you got it wired up.
    What input are you using, have you got the freeview tuner active.
    On the options menu for each input you need auto size on and check input select settings.
  8. stranger
    stranger
    May 29, 2003
    2,553
    5
    137
    Manchester
    +869
    The 507 aspect ratio should be set to 'full' not 'wide' (confusing I know)
  9. amrad
    amrad
    How do i set the aspect ratio to full? Is this on the screen or through sky?
    "On the options menu for each input you need auto size on and check input select settings."
    Again is this on sky or the screen?
  10. stranger
    stranger
    May 29, 2003
    2,553
    5
    137
    Manchester
    +869
    Use the bottom right hand button on the tv remote (says HDD underneath it)
