pioneer pdp502mxe
Discussion in 'Plasma TVs Forum' started by Splatt, Jan 5, 2003.
  1. Splatt
    Splatt
    have 502 mxe with pda5001 video board is there any way i can get pal prog on this either by the setup menus or can i change the video card for later versions (have found hidden menu on startup which says HDTV 1080i mode but unable to change)
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    Just to avoid confusion, the PDA-5001 is actually an external box that attaches to the back of the screen rather than a slot in card like the PDA-5002.
    There was a version of the 502MX that had built-in video facilities but I believe that was USA/Japan only.
    The PDA-5001 manual indicates that it supports 480p, 720p and even 1080p and it does show support for 50Hz based signals but it doesn't indicate any more than that.
    However, it does claim to support 31.25kHz horizontal at 50Hz vertical, which is I believe the right settings for PAL progressive.
    Have you tried to give it a progressive signal ?
    Mark
  3. Splatt
    Splatt
    yes but picture is unstable with coloured bars going up the screen
