Pioneer PDP502MXE Plasma I will get one I think
Discussion in 'General TV Discussions Forum' started by DaveH, Aug 20, 2001.
  1. DaveH
    DaveH
    Aug 1, 2000
    743
    28
    Surbiton, Surrey
    +34
    Dear all,
    After the immense probs I have had with a CRT TV I have decided to purchase the above beast.
    I am aware of plasmas limitations of blacks and lifespans etc.
    However, I saw one in action and must say I am impressed.
    Are there any other plasma owners out there who can comment on the above set?
    thanks.
    Dave.
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,581
    WEST MIDLANDS
    +1,434
    Lucky Bugger <img src="biggrin.gif" border="0">
    I had a demo of the Pioneer Plasma when i bought my Dvd player they used the Progressive Component output from a DVD939 with a clip of Gladiator.
    I was blown away by the detail and the depth of colour and all this sitting only about 10 feet from the screen.
    Good luck with the purchase hope you enjoy it.
    Cheers Carlos
  3. simoncope
    simoncope
    Yep, the 50" Pioneer is V good indeed - it has been our "most specified 50" screen" award winner for the last couple of years. However, I believe it is to be replaced before the end of the year (not gospel truth)......
    I will be getting my hands on a 50" NEC screen when I get back from Moscow next week - but only for a short period of time. If you are interested in getting a look before it goes back, get in touch.
