Pioneer PDP436XDE set up.
Discussion in 'Plasma TVs' started by pdlewis, Sep 5, 2005.
  1. pdlewis
    pdlewis
    Aug 30, 2005
    19
    3
    Hi all,
    I'm looking to put a new home cinema kit together and was wondering if this is the best set up to do, i.e. is everything compatible and the best I can get for the money I'm spending?
    Pioneer PDP436XDE (Plasma Screen) (£2,499)
    Pioneer VSX1015 (A/V Receiver) (£360)
    Denon DVD 1920 (DVD Player) HDMI (£239) OR Pioneer DV-585A (£119)
    Pioneer S-V410 (Home Cinema Speaker set) (£349)
    As you can see I like Pioneer products! Any help reviews on the products I'm looking at or suggestions for quality alternatives would be welcome.
    Cheers,
    Paul
  2. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Im probably going to go for a very similar setup (same TV and amp - although I hear there is a new Pioneer HDMI switching amp coming out soon).
    The speakers I was considering are S-VLF3, but I have heard you can easily do better than Pioneer for speakers.
    I will share reviews as/when I find them. Are you going to wall mount?
