Pioneer PDP436XDE help, warranty expires today.
Discussion in 'Plasma TVs Forum' started by Gixer1970, Dec 23, 2006.
  1. Gixer1970
    Gixer1970
    Nov 15, 2005
    1,115
    Kent (UK)
    +114
    Hi all, this morning when I turned on my Pioneer PDP 436 XDE I had the following message,
    The aerial cable has short-circuited. Check the cable and plug in the AC power supply again.
    So I turned off the power and disconected all cables and re set up also using the option of turning the power off for the aerial in the menu settings.
    The more worrying issue I have is that when all power is off, I now have a solid black line all round the screen of about 5 pixels deep which I have never noticed before. This is also present when turned on in any mode. I purchased the unit on the 23rd December 2005 so warranty expires today at midnight.
    Contacted Pioneer and they are closed until 2nd January.
    Any ideas on whats happened and has anybody had the same problem?
    Many thanks.
  2. keefers
    keefers
    Nov 6, 2003
    337
    Warwick
    +12
    My panel never uses 6 columns of pixels either side & 3 rows at the top & bottom of the screen meaning they are always black. Is this what you mean?
    I don't quite follow how you have these black areas when the screen is switched off - surely the whole screen is black when the power's off? :confused:
    K.
  3. Gixer1970
    Gixer1970
    Nov 15, 2005
    1,115
    Kent (UK)
    +114
    When the power is off the whole screen is dark grey to black, but the pixels in question are jet black as the bezel, I am sure after owning this for one year this has not been the case, but i stand to be corrected. Are your pixels jet black when powered off around the outer edge ?
  4. chaparral
    chaparral
    Apr 8, 2006
    1,982
    Planet Earth
    +375
    You could Send them an e-mail today and post a Special Delivery letter...
    This way you have proof that the fault was within the warranty period..
  5. keefers
    keefers
    Nov 6, 2003
    337
    Warwick
    +12
    I can confirm those pixels around the outside are darker than all the other pixels when the screen is off so I don't think you have anything to worry about there :clap:
    K.
  6. Gixer1970
    Gixer1970
    Nov 15, 2005
    1,115
    Kent (UK)
    +114
    Many thanks for looking, I was starting to get a major panic on there, paranoid now about the warranty. I can't believe it's taken me a year to spot this, and it gets cleaned every day :thumbsup:
  7. Scaleyback
    Scaleyback
    Dec 18, 2004
    132
    Newport
    +9
    Gixer.
    Did resetting all the connections sort out the aerial short circuit message?
    I've just changed my set up around as I've bought a new DVD player and I'm getting the same message when I turn my display on. There are no issues with images but....
    My Warranty expires Mid Jan so your post has got me paranoid
  8. CFC1
    CFC1
    Mar 16, 2006
    15,870
    Europe
    +4,213
    Huh! I've never cleaned mine (plasma, I mean)... am I a dirty so and so?
  9. S3rv3d
    S3rv3d
    Jun 3, 2005
    1,026
    83
    +268
    What causes this message? I got it when i turned mine on when i got back from work. My warranty runs out in september, so havent really got anything to worry about for now. I switched the panel off unplugged the aerial then plugged back in and it had gone?
  10. cosmicveg
    cosmicveg
    Oct 15, 2007
    11
    3
    I know its a little late but that message is nothing to worry about. You have somehow got aerial power switched on. This outputs a small voltage on the aerial cable to operate a masthead amplifier, not much call for that in this country. Your TV will work fine with this error or alternatively switch antenna power off in the setup menu.
