Pioneer PDP435xde Set up issues.
Discussion in 'Plasma TVs Forum' started by swall101, Jan 7, 2005.
  1. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    Hi all
    Installed my Pio 435xde today, used component for dvd and also for sky+(with JS Tech rgb to component convertor). Top quality cables used.
    Dvd picture is awesome, but the sky+ picture is a bit ropey. I am waiting for the Digital Video Essentials disk to be delivered which I hope will help me calibrate the PQ, but has anyone got any other advise to improve the picture.
    Well pleased with overall package, my first plasma and its like all my christmas's rolled into one!!!
    cheers
    Steve
  2. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    I just wondered why you chose to go component with both the dvd player and sky? I appreciate that component is a better connection with a dvd player that outputs component but I'm not really sure what advantage you're getting converting sky to component.
    If I'm correct, you've got both of these running into the same av socket. The problem I'd find with this is that the picture settings I use for sky+ are different to that I use for my dvd picture. For example, on my dvd picture, I tend to switch all the enhancements off whereas my sky+ on the lower bitrate channels looks better (in my opinion) with mid/low settings on enhancement.
    This would mean that I'd be changing settings all the time or, at the very least, setting "user" and another setting and changing between them all the time. Would you not have been better off simply going sky box via RGB to AV1?
    Should say that I've not seen sky converted to component so have no idea if this is better or not.
    If it's just picture settings you're having trouble with, the usual advice given on the forums is to lower the contrast and brightness while the set is running in. Personally, I also find the colour way, way too high for my liking. Again though, I need different colour level setting on my dvd than my sky+.
    Hope this helps and that you enjoy your screen.
  3. rajvirdee
    rajvirdee
    I have a 435 connected to sky+ with rgb scart and have no issues with the pq at all. I haven't even messed around with the settings much, other than turning the colour down.
    Please ensure both the pio and the sky box are set to RGB mind.
    Rgds
    Raj
  4. jayk
    jayk
    Nov 21, 2004
    11
    dvd settings through hdmi
    all pro adjust settings to off except
    color temp mid
    dre mid
    contrast 28
    brightness 7
    colour -5
    tint 2
    sharpness -3
    sky/dvdr through rgb scart
    colour temp mid
    dre mid
    contrast 28
    brightness 5
    colour -8
    tint 0
    sharpness -3
    using pal dve disc
  5. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    Thanks for your replies. The reason I converted the Sky+ to component was to enable me to use the amplifier to switch both video and audio signal as follows:
    Denon 2900 DVD Component to Denon 3802 amp.
    Sky+ to JS Tech RGB to Component convertor using QED Sqart AV41.
    JS Tech RGB to Component convertor Component to amp.
    Amp component to Plasma media box.
    All component cables are top quality made by Mark Grant.
    I'm waiting for the Digital Video Essential disk to arrive (posted on 31/12/04 from Blah.com and still waiting!!!!!) to do some more detailed calibration.
    It is only the Sky that I'm having difficulty with, mainly the picture looking really grainy and dull.
    If anyone has any more settings to suggest I would apprieciate it. :lease:
    cheers
    Steve
  6. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    Still playing about..... Football on Sky Sports as well as cricket is absolute :censored: ......... Come on guys any ideas, or I'm just gonna have to shell out some of my hard earned on getting an expert in. Phoned Sevenoaks Sound and Vision who quoted me £50.00 pound an hour and that inclduded travel time!!!!
    Heeeeeeeellllp :lease:
  7. jayk
    jayk
    Nov 21, 2004
    11
    football or cricket will never look great.....theyre both crap games anyway so dont worry.Make sure all digital filters etc are off
  8. cucuz
    cucuz
    Jun 16, 2004
    123
    +6
    I think Gordon at http://www.convergent-av.co.uk/ is the man you need . I also seem to remember someone posting ( I think it was Joe at TMF ) about some software specifically for the XDE range of Pioneers that removes a geat deal of digital noise ( again something to speak to Gordon about ) .
  9. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,175
    Norwich
    +795
    I really don't like the image the Pioneer gives with Sky.
    I was all set to buy an MXE1 but ended up with a PW6, just because it seemed to handle Sky far better and this is used as a TV.
    And now with the Sky HD and hdcp issues I would like to change to an XDE but worried I will hate the picture on Sky, I watch loads of sport and find the pictue stunning on the Panasonic.
    What exactly is wrong with the picture on sports for you? the thing I found with the Pioneer (on sports) was there seemed to be more processing going on that you couldn't turn off, the image would smear alot and the colours were over saturated. Obviously the last one you could rectify and that also seemd to help the smearing a bit.
  10. danny daniell
    danny daniell
    Jul 25, 2004
    1,649
    2
    +149
    Paul Miller recently reviewed the XDE for AVTech mag,here are his recommended settings:
    Picture >AV Selection >Standard
    >Contrast >40
    >Brightness >0
    >Sharpness >0
    Pro Adjust >Colur Temp >Mid-Low
    >Pure Cinema >Off (TV)/ Adv (DVD)
    >DNR/CTI/DRE >Off
    Dan :)
  11. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    Got the DVE disk through today, had a fiddle and I'm getting nowhere!!!
    Does anyone know any professional calibration experts in the Kent area who could do a set up for me at a reasonable price?
    cheers
    Steve
  12. scrowe
    scrowe
    Jan 8, 2005
    1,103
    116
    Brighton
    +637
    Sharger,
    Best advice I can give is don't panic. I got a 505XDE before Xmas, my first Plasma.
    DVD via component was fantastic from the get-go, but Sky Digital via RGB was not so great, worse that the 46" Rear projection picture I'd had before.
    However, the dealer had pre-warned me on purchase that he'd had one at home and he said he was unsure about the PQ on SKy but after running it in for a couple of weeks it came good.
    And he was right, after confirming via a bit of research on this forum that Plasmas need a good 100-200 hours run-in, I was just patient.
    The picture via Sky is now very good, and I am 100% satisfied. I don't watch Cricket but football is just never going to be great on this set. It's actually fine for most picture angles but when you get a pitch-wide camera the players just turn into small pixel-blurs. The other thing that really looks crap is when Sky combine pictures with graphics, ie. the pre-game lineup that shows players faces in their positions.
    I would also try Sky via RGB scart and compare to your compinent converter just in case that is causing any issues.
  13. scrowe
    scrowe
    Jan 8, 2005
    1,103
    116
    Brighton
    +637
    Just to clarify, there's no point calling in a calibration expert until it's done is 100-200 hours run-in anyway. I'm guessing it would be a waste of time and money, and any calibration experts would hopefully wait until that period had expired before agreeing to come and have a look.
  14. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    H Scrowe
    Thanks for the advise. When you say run in would you recommend leaving the screen on permenantly or would this cause damage with overheating etc?
    cheers
    Steve
  15. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    Hi Scrowe
    When you say run in would you advise leaving the screen on 24/7 or will this cause damage?
    cheers
  16. swall101
    swall101
    Dec 29, 2004
    1,983
    +262
    H Scrowe
    cheers
    Steve
  17. scrowe
    scrowe
    Jan 8, 2005
    1,103
    116
    Brighton
    +637
    Perhaps do a search of this forum for ways of doing this.
    Personally I just watched the TV ordinarily, the usual 3-4 hours a night. My TV is normally on all the time I am in as background, even when I do other things. I perosnally wouldn't have been comfortable leaving it on all night or whilst I was at work.
    However, you could possibly make use of it's power-off function, and let it run in for at least a couple of hours every night.
  18. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Scrowe
    Do you know how to access the srvice menu on oyur 505XDE, I bought one 5 weeks ago and want to see how many hours I have used it for so far?
  19. scrowe
    scrowe
    Jan 8, 2005
    1,103
    116
    Brighton
    +637
    No, sorry. However, I'm sure I've seen a couple of posts saying it is the same as previous Pioneer models, try a search on Pioneer Service Menu
  20. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Thanks Scrowe. I have tried the method for the 434 which other 435 owners say works for theirs (505 should be same) but to no avail, I must be doing something wrong.
  21. scrowe
    scrowe
    Jan 8, 2005
    1,103
    116
    Brighton
    +637
    Actually you piqued my curiosity and I tried it.
    You need to put the panel and media box in Standby
    On the remote :-
    Press 'Channel Info' i+ button next to '0' and wait a few seconds
    Press 'Left' 'Up' 'Left' 'Right' and then the orange standby/power button
    You should then be in the Service menu, although it took me 3 attempts
    Up and Down scrolls pages and you will then see the hours
    Mines at 166H 20M
    Turning back into standby and on again gets you back to normal
    Use at your own risk, obviously
  22. CharlieR
    CharlieR
    Jan 4, 2005
    45
    11
    Glasgow
    I tried this and didn't get any further than the first button as it switched the Receiver and Screen on :confused:
  23. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Scrowe
    Yeah thats the method I have tried but just can't seem to get it to work. Scrowe have you got a 505XDE? may be it is different for the 50 inch (shouldn't be) is there anybody out there that has managed to get this to work on a 505XDE? :lease:
  24. jayk
    jayk
    Nov 21, 2004
    11
    works on my 435xde so will work on 50" model as they both use the same media box,panel size has nothing to do with it .Its simply down to the media box,xde,fde etc both 43 and 50 xde use same media box so it should work.Took a few attempts but if you press channel info button and then wait about 3-4 secs you should hear a clicking type noise from media box then perform the rest of the procedure and you should be into service mode
  25. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    How close are you to the screen when you are watching the footy?
  26. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Thanks will give that a go.
  27. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Jayk
    Thanks Dude, got it ot work at last :)
    Power on 200
    Panel 319H 10m
    MR 318h 21m.
    Any idea what Panel PD and Panel SD means aslo MR NG?
    Once again cheers dude
  28. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Are you saying that the info button switched the Panel and media box on?
  29. bingle
    bingle
    Does accessing this menu void the warrenty in any way?
    I took delivery last week of an XDE. Very impressed, though one or two tiny problems:
    Is it me or does the time and date have to be re-entered every time you turn the box off by the front power button? Obviously it can be left on standby, but I find this very strange for a £3000 piece of gear.
    I've been trying to get my Sky+ remote working- is it possible? Anyone have working codes they are willing to share? :)
  30. cashlessbond
    cashlessbond
    Jan 1, 2005
    1,225
    Epsom, Surrey
    +45
    Mine does the same but that's because I haven't got it connected to an aerial. Think the Media box needs to be connected to a standard aerial to keep the clock correct. Have you got yours connected to Sky? if so then that's probably why you have to keep resetting your clock. I run my sound through my amp and use a Sony 3100 programmable remote commander for all my system so don't use the sky remote, remote eats the batteries though.
