Pioneer PDP435XDE buzzing noise
Discussion in 'Plasma TVs Forum' started by javy2003, Nov 28, 2004.
  1. javy2003
    javy2003
    Nov 28, 2004
    I recently bought a Pioneer Plasma TV model PDP435XDE and found the plasma (not the receiver) especially noisy(buzzing noise)
    I find it very annoying, :confused: ¿is normal ?
    Thanks.
    Greetings to all.
  2. goatlips
    goatlips
    Nov 22, 2004
    272
    Croydon
    I have a 434 and that has started buzzing too. Not sure what to do? It's only 6 months old.Mind you cannot hear it at ref volume levels.Ha Ha.
  3. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    I have a 434 too. Does your buzz vary with the picture being shown on the screen? If so, its probably faulty and you should return it until you get one that doesn't buzz. This is the road I had to go down with my retailer (JL).
  4. Xstyle
    Xstyle
    Sep 27, 2004
    3,496
    Berkshire
    +146
  5. jwramsay
    jwramsay
    Sep 7, 2004
    1,628
    West of Scotland
    +71
    Much better but not silent.
