pioneer pdp435fde
Discussion in 'Plasma TVs Forum' started by kp090, Jul 21, 2005.
  1. kp090
    kp090
    Hi ive had my pioneer plasma for about 3months now and only noticed recently that the plasma keeps making these sudden noises every now and then. Its not the noises such as the buzz but its more like crackly pop sorta noises... its hard to describe but its sorta the noise like if u press hard down on the plastic areas of the keyboard... it makes the same sorta noise lol
    does any get this noise at all or is it just me hearing things?
    thank you in advance for the people who do try to help
  2. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    Does it get a lot of sunlight on it.......?
    If it does it could be the screen expanding and contracting, especially with all this hot weather we have had latley.
  3. kp090
    kp090
    thanx for your reply.... id say that the screen doesnt get alot of sunlight on it but like even if there was no sun about it still make the noise?
    even having picture problems like with sky... this plasma screen i saw it on a gagdet show on ch5 read reviews sayin it was too good, all i had is problems with it
  4. spylab
    spylab
    May 9, 2005
    368
    Athens Greece
    +17
    User Instructions of Samsung-PS42S5H
    The product is making a ‘cracking’ noise.
    A ‘cracking’ noise may occur when the product contracts or expands due to a change of
    surrounding environment such as temperature or humidity. This is normal and not a defect of the unit.
  5. kp090
    kp090
    ok thanx alot people for helping, thats a relief its nothing major
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    I'm sure you are not the 1st person to mention this noise, I think all Pio consumer models do it at least a bit. Your sky picture problem, I take it you've done all the usual, enable RGB on sky and plasma, turn off all noise reduction stuff?
