Pioneer PDP435FDE Connections
Discussion in 'Plasma TVs Forum' started by pjwhitehouse16, Apr 26, 2005.
  1. pjwhitehouse16
    pjwhitehouse16
    Hi I am new to plasma as well as AVForum so forgive any inaccuracies.
    I have just brought a Pioneer PDP435FDE which replaces the previous flat-owners pioneer plasma. He had left the power cable and connections to the media box fixed behind the wall. Annoyingly the connector to the media box are just a little short of the sockets in the tv. I have managed to buy a 1m extension cable for the DVI (white) cable but can't find anything similar for the black connection which I believe is unique to Pioneer. Does anyone know where I can get an extension or a male/female adaptor so I can connect the cables supplied with the tv? I know that pioneer sell the 10m cables but I really need an extensions because the existing cables are fixed into the wall.
  2. SPURS1882
    SPURS1882
    Sep 16, 2004
    395
    Gants Hill
    +16
    Try www.leconcepts.com, they have the PDP-H02 in stock.
    This is the 7m extension cable and is priced at £169.99
    Hope this helps
    Michael
  3. pjwhitehouse16
    pjwhitehouse16
    Thanks Yid,
    I think this is a replacement cable to run from the media box to the tv. I need a way to connect the 2 cables (the one in the wall from a previous Pioneer installation and the one supplied with the tv) somehting like a male/female addpator or a new cable with male and female connectors.
    If I can't buy one like that do you know anywhere that will make them up?
    The annoying thing is I tried pulling the one in the wall through and I am literally about an inch short (no jokes, please)
